Using Expressions to animate smooth light movement
COW Forums : Adobe After Effects Expressions
Cameron Crook
on Aug 13, 2011 at 12:50:00 am
Hi, I am trying to figure out how to use expressions to animate a light with smooth movement. I am using the light as an emitter and don't want to manually animate it, because I have a extremely long clip. The wiggle function is out of the question because its movements can be rough and sharp. I am trying to have the light to emit particles that are evenly space from each other while moving in 3D space. Any help is appreciated.
Stefan Hinze
Re: Using Expressions to animate smooth light movement
on Aug 14, 2011 at 1:49:10 pm
hey,
give the wiggler a chance - maybe you set the "wiggles per second" to 0.5 or lower, so there will not be sharp movemend
wiggle(0.5,400)
greetz
(take a step back, to see the bigger picture)
Tylor Larson
on Aug 23, 2011 at 9:35:02 pm
http://jjgifford.com/expressions/basics/interpolation.html
this is a link to add easing to your expression... maybe adding this to a wiggle might smooth things out enough. sorry don't have time to test it... good luck
