Change comp duration
COW Forums : Adobe After Effects Expressions
Stanislaff Fabiyanskiy
on Aug 10, 2011 at 4:45:39 pm
How i can change composition duration with a script?
like this
var change = app.project.activeitem.duration
make change + 500 frames
thanks
Dan Ebberts
Re: Change comp duration
on Aug 10, 2011 at 5:46:48 pm
I'm not at a compute with AE installed right now, but this should work:
var myComp = app.project.activeItem;
myComp.duration += 500*myComp.frameDuration;
Dan
on Aug 11, 2011 at 1:36:05 pm
thanks thanks thanks!
luis palencia
on Sep 13, 2017 at 1:40:40 pm
Where do you write this expression? in a layer? can you send a screenshot plis? thank you very much!
Dan Ebberts
on Sep 13, 2017 at 5:10:00 pm
It's not an expression, it's a script. So you would run it either in the ExtendScript editor, or as a stand-alone .jsx file using AE's File>Scritps>Run Script File... menu item.
Dan
luis palencia
on Sep 13, 2017 at 6:51:52 pm
Oh thank you very much.
Is there any expression that allows adjust the duration of a composition?
What I want to do is change the duration of many composition, each composition has a layer text, I want to change the duration of composition as long as the length of the text.
For example:
Composition1
Text: "Hello, Word"
Duration of Composition1 = 5 seconds (for example)
Composition2
Text: "Hello, Word. The sky is blue and the children play in the park"
Duration of Composition2 = 15 seconds (for example)
I want to calculate the length of the text with "text.sourcetext.length" and that multiplicate for 1 second and the result apply to the duration of that composition.
Can you help me t_t ???
Dan Ebberts
on Sep 13, 2017 at 6:59:52 pm
An expression can't do that. You could do it with a script, but you'd have to run the script each time you wanted to update the comp durations.
Dan
luis palencia
on Sep 13, 2017 at 8:02:55 pm
And an expression to modify the duration of a text layer?
Dan Ebberts
on Sep 13, 2017 at 8:09:48 pm
Expressions can't modify the duration of anything. The best you could do is an expression to control the opacity. Otherwise, it would have to be a script.
Dan
