Z-rotation linked to two points - one is 3D and the other 2D
COW Forums : Adobe After Effects Expressions
Roland R. Kahlenberg
on Aug 1, 2011 at 5:25:59 am
Hi peeps, I'm looking for an Expression to link the Z-rotation property of a layer from two points residing in two separate layers - one is 3D layer and the other is 2D.
TIA
RoRK
Intensive AE & Mocha Training in Asia.
Dan Ebberts
Re: Z-rotation linked to two points - one is 3D and the other 2D
on Aug 1, 2011 at 1:20:28 pm
Are you talking about something like this?
L1 = thisComp.layer("2D Layer");
p1 = L1.toComp(L1.anchorPoint);
L2 = thisComp.layer("3D Layer");
p2 = L2.toComp(L2.anchorPoint);
v = p2 - p1;
radiansToDegrees(Math.atan2(v[1],v[0]))
Dan
on Aug 1, 2011 at 2:04:19 pm
That works well Dan BUT I've found another issue. Here's the scenario -
I have the Beam effect linking the two points mentioned. I would like to place a Text Layer along the Beam; centered will be fine but it'll be better if I am able to move the text anywhere along the Beam.
Right now, the Z-rotation for the text layer looks good but there are instances where the text strays away from the Beam.
Cheers
RoRK
Dan Ebberts
on Aug 1, 2011 at 6:48:14 pm
This should position the text anchor point at the center of the beam:
(p1 + p2)/2
You could add a Position animator tied to sliders to adjust the x and y, if necessary.
Dan
on Aug 2, 2011 at 4:40:11 am
Awesome! How can I convert my 2D Beam layer (Solid) to a 3D layer (cos I'd like some 3D shadows) and keep everything sexy?
TIA
RoRK
