Parent to an object in another Comp
COW Forums : Adobe After Effects Expressions
Johan Nordström
on Jul 20, 2011 at 10:07:24 am
Hi!
I'm so new att expressions, and i'm sure this has been up on the forum before.. but im having a hard time finding the answer.
Here we go.
I want a pre-composed shape layer to parent to a layer in the original composition. I want it to move and scale exactly like the original image but in the pre-comp.
thnx.
Greg Burrus
Re: Parent to an object in another Comp
on Jul 20, 2011 at 2:57:59 pm
If I understand you correctly you just want to know how you connect values between comps.
If that is it you can drag one compositions timeline panel above the other by clicking and dragging the tab above until you see the blue shapes that tell you where you are placing it.
Then you can just pick whip the values from one composition to the other.
If you happen to have expression controllers you can lock the effects panel with the lock in the tab then open the other composition and pick whip the values.
or you can just type the code below
hope this helps
greg
comp("Comp name").layer("your layer name").value
http://mogra.g2bproductions.com/ - Blog
http://g2bproductions.com/ - Portfolio
Johan Nordström
on Jul 20, 2011 at 3:58:32 pm
Yes!
Thank you!
I didnt think of that.. it was sooo easy...
Thank you so much!
