sliders to control time between keyframes
COW Forums : Adobe After Effects Expressions
Mike Throck
on Jun 11, 2011 at 4:05:45 am
I have an object that moves from one place to another, holds there and then moves to another location and scales up.
I'd like to control the amount of time it holds with an expression slider, and not have to move any of the scale keyframes.
I'm not very experienced with expressions, so any help is appreciated.
Dan Ebberts
Re: sliders to control time between keyframes
on Jun 11, 2011 at 2:31:58 pm
I'm not sure if this is exactly what you're after, but you would apply this expression to both the position and scale properties. It's set up to substitute the slider value for the time between position keyframes 2 and 3 (change the values of k1 and k2 if it should be a different pair):
holdTime = effect("Slider Control")("Slider");
k1 = 2; // 1st hold keyframe
k2 = 3; // 2nd hold keyframe
p = transform.position;
t1 = p.key(k1).time;
t2 = t1 + holdTime;
if (time < t1)
t = time
else if (time < t2)
t = linear(time,t1,t2,t1,p.key(k2).time)
else
t = p.key(k2).time + (time - t2);
valueAtTime(t)
Dan
Mike Throck
on Jun 11, 2011 at 6:52:17 pm
This is exactly what I needed, thank you much! It even still recognizes the easy ease.
Mike Throck
on Jun 11, 2011 at 9:50:24 pm
Your answer was so helpful, I was hoping you could help me add one more element.
As the object scales up I want it's parent object's ( a null) Y position to animate in time as well. The expression you already gave me would do this, but I would like the value of the Y position to be controlled by a slider as well.
How do I get the Null's second keyframe to be driven by a slider and still work with the other expression.
you are the man, of course.
Dan Ebberts
on Jun 11, 2011 at 10:31:26 pm
OK, you lost me. I thougt I was with you until you mentioned the null's 2nd keyframe. Are you just talking about adding the value of the slider to the null's y position, or is this another timing-control slider?
Dan
Mike Throck
on Jun 11, 2011 at 10:37:35 pm
I guess what I'm after is this:
I'd like the anchor point, scale and posY to be controlled by sliders but I'd like to just enter a value and not have to adjust keyframes.
Much like the time between them is controlled by a slider where I enter a number. Is it possible to have a slider determine one keyframes value but not the other?
Dan Ebberts
on Jun 12, 2011 at 12:01:24 am
So you want to be able to substitute a value at a particular keyframe, is that correct? If so, which one, the last one?
Dan
Mike Throck
on Jun 12, 2011 at 12:24:54 am
Yes, and the second of the 2 keyframes.
I basically want to be able to change the value of a keyframe using a slider control, without having to scrub to that point in time.
Dan Ebberts
on Jun 12, 2011 at 12:59:55 am
The only way I can think of would lose any easing or deviation you had built into the keyframes. It would go straight from the value at keyframe 1 to the slider value, using the timing generated with the previous expression. Is it still worth doing?
Dan
Mike Throck
on Jun 12, 2011 at 1:03:39 am
I guess not, the easing is important.
I'm building a template for people who don't know after effects very well and I wanted to make it as easy to use as possible.
Thanks for all your help, especially on a Saturday!
Lukasz Lindell
on Jun 15, 2011 at 1:23:54 pm
t2 = t1 + holdTime;
if (time < t1)
t = time
else if (time < t2)
else
valueAtTime(t)
Hijacking this thread a litte, but this was exactly what I was after. I tried to add more keyframes to hold, up to 10. I started out with adding to the:
and created:
k3 = 4; // 3rd hold keyframe
and so on, up to k10. Then I added:
t3 = t2 + holdTime;
t4 = t3 + holdTime;
Guess I'm doing fine so far, but here my little skills ended. How do I keep on adding to this expression? This part really messed it up for me:
if (time < t1)
t = time
else if (time < t2)
else
Dont know where to go from here though...
Dan Ebberts
on Jun 15, 2011 at 3:25:21 pm
I guess it would be like this:
k3 = 4;
k4 = 5;
k5 = 6;
k6 = 7;
k7 = 8;
k8 = 9;
k9 = 10;
k10 = 11;
t2 = t1 + holdTime;
t3 = t2 + holdTime;
t4 = t3 + holdTime;
t5 = t4 + holdTime;
t6 = t5 + holdTime;
t7 = t6 + holdTime;
t8 = t7 + holdTime;
t9 = t8 + holdTime;
t10 = t9 + holdTime;
if (time < t1)
t = time
else if (time < t2)
else if (time < t3)
t = linear(time,t2,t3,t2,p.key(k3).time)
else if (time < t4)
t = linear(time,t3,t4,t3,p.key(k4).time)
else if (time < t5)
t = linear(time,t4,t5,t4,p.key(k5).time)
else if (time < t6)
t = linear(time,t5,t6,t5,p.key(k6).time)
else if (time < t7)
t = linear(time,t6,t7,t6,p.key(k7).time)
else if (time < t8)
t = linear(time,t7,t8,t7,p.key(k8).time)
else if (time < t9)
t = linear(time,t8,t9,t8,p.key(k9).time)
else if (time < t10)
t = linear(time,t9,t10,t9,p.key(k10).time)
else
t = p.key(k10).time + (time - t10);
valueAtTime(t)
I haven't tested this and there are probably better ways to code it, but hopefully it will do what you want.
Dan
Lukasz Lindell
on Jun 17, 2011 at 10:38:36 am
Thanks a lot Dan, that will work!
Greg Antisdel
on Nov 3, 2014 at 8:53:08 pm
Hi Dan,
This expression is awesome! I was wondering if we could specify a min and max range for the slider?
For example, if the value entered by the slider is a negative number, the animation will continue normally up until the second keyframe and then the next frame it will snap to the fourth keyframe. If the value entered by the slider is longer than the animation, the third and fourth keyframes will never be reached.
I was thinking something along the lines of
if (holdTime<3);
t=3
else if (holdTIme>28);
t=28
else
But I am obviously missing something.
Any help would be greatly appreciated.
Greg
Greg Antisdel
on Nov 4, 2014 at 3:34:33 pm
I just figured out that I can set the range on the slider itself, so no need to worry about the code.
Hung Nguyen Dac
on Dec 25, 2014 at 10:13:22 am
Hi Dan. Your code worked with "tranform", but i wanna use this code for Shape "path\shape1\path-stroke-fill-tranform".
I was changed "p = transform.position; => p = contents.shape 1.path;"
But it doesn't work. Please help me.
Dan Ebberts
on Dec 25, 2014 at 6:37:21 pm
Which property has the keyframes? Which property has the expression? Are you getting an error message? If so, what is it?
Dan
Hung Nguyen Dac
on Dec 26, 2014 at 2:53:41 am
I have 2 problems:
1.I want to use your code with other properties. Ex. Shape and Mask (like this picture), but it always show error occurred at line 4. I think I was the wrong path.
2. I had 12 keyframes.
- If I start with "k1=2", after I'm increased slider, then keyframes: 3,4,5,6,7,8,9,10,11,12 also increase value of the slider. I only want it to affect keyframes:11, k12
- If I start with "k1=10" then the time of motion begins at keyframe 10 while I want it to start at keyframe 2. I don't want it affect to keyframe 3->10
Dan Ebberts
on Dec 26, 2014 at 4:41:39 am
Try changing the 4th line to this:
p = thisProperty;
and see if that eliminates the error. I'm not sure what the second part of your question is asking though.
Dan
Hung Nguyen Dac
on Dec 28, 2014 at 10:52:01 am
Thank Dan! I was corrected 2 problems.
1. I used "p=thisProperty;" and it worked with Shape and Mask.
2. I just change "t2 = t1 + holdTime;" => "t2 = t1 + holdTime - (second);"
I have a new problem. I use this code. It can scale layer by slider, but it doesn't work with keyframes in this layer. How to make it correct?
x=100; //100% Comp
y=100; //100% Comp
t=thisComp.layer("Scale").effect("Scale Y")("Slider");
if (t>=y)
[x,y]
else
[x,t]
Dan Ebberts
on Dec 28, 2014 at 5:43:43 pm
It's hard to say for sure, but you might be looking for something like this:
[value[0],value[1]*t/100]
Dan
Hung NguyenDac
on Jan 1, 2015 at 5:39:42 am
It's worked. New Year has come, allow me to congratulate you and your family all my best wishes for perfect health and lasting prosperity in the New Year :)
