Trying to duplication a cool effect
COW Forums : Adobe After Effects Expressions
Taki Oldham
on May 17, 2011 at 9:21:10 pm
I am an editor without much AE knowledge but I find myself needing to do a small animation for a job. I looked around and really like the way an Australian TV show "Hungry Beast" does animated diagrams to convey a mass of facts and information. Here is an example:
I am trying to replicate the effect where the images appear by rotating into view and then moving back and forth a little at the end, like they were spring loaded.
I played around with expressions based on the Motion Script simulations:
but these dont work with the orientation parameter it seems. I get an error message, see attached for screenshot:
I am wondering if anyone knows how to achieve this by either using expressions OR another method / plugin I am not familiar with.
Many thanks,
Dan Ebberts
Re: Trying to duplication a cool effect
on May 17, 2011 at 10:37:26 pm
Try this. Where you want the animation to start, set a keyframe for x rotation with a value of -90 degrees. A few frames layer, change the value to 0. Add this expression:
n = 0;
if (numKeys > 0){
n = nearestKey(time).index;
if (key(n).time > time) n--;
if (n > 0){
t = time - key(n).time;
amp = velocityAtTime(key(n).time - .001);
freq = 2;
decay = 3;
w = freq*Math.PI*2;
value + amp* Math.sin(t*w)/Math.exp(decay*t)/w
Adjust freq and decay to suit your needs.
Taki Oldham
on May 18, 2011 at 1:20:48 am
Thank you so much Dan.
Just pasted it in and it worked straight away!
I can't tell you how much I appreciate your taking the time to respond to me.
Maybe I can return the favour. I have a new documentary out: -> If you would like a free copy I'd be happy to send one wherever you are. Otherwise just a big thanks from me.
© 2018 All Rights Reserved
