Particles position to write-on effect doesn't work. Advice needed.
COW Forums : Adobe After Effects Expressions
Robert Hoisan
on May 16, 2011 at 10:39:21 am
I know i did this before but i can't figure it out why it doesn't work.
I have a particles generator , CC P Systems II, AE CS5 and a simple shape revealed by the write-on effect ( white line in the picture). I used the pickwip to trigger the particles position by the position of the Write-on brush and it's not working. The particles are indeed fallowing the motion of the write-on effect but it should be in the same position instead i am having this strange distance.
I even tried to copy and paste the key frames, same result.
Any ideas?
Robert Hoisan
Motion Graphics Artist
Kevin Camp
Re: Particles position to write-on effect doesn't work. Advice needed.
on May 16, 2011 at 4:10:28 pm
there are two possible problems from you screen grab... one the expression is disabled for the producer position. and 2 the layers they are applied to are 3d layers, so if those layers don't line up in z space (actually they need to line up on all axes), then the other positions won't line up either.
Kevin Camp
Senior Designer
KCPQ, KMYQ & KRCW
Robert Hoisan
on May 16, 2011 at 5:10:48 pm
Yes, the layers did not line up in 3D space. I just copyed the position proprieties from one layer to another and now it works perfect. Thanks a lot!
Robert Hoisan
