Changing Color Overlay at keyframes?
COW Forums : Adobe After Effects Expressions
Josh Pigford
on Apr 15, 2011 at 9:56:25 pm
Currently I'm setting the color in Color Overlay of a layer using this:
comp("SETTINGS").layer("BLUE").layerStyle.colorOverlay.color
Easy enough.
But now I want to add an additional key frame on that layer so the color changes.
Is there a way to use an expression to set the color at one key frame but then transition to the other color by the next keyframe?
Dan Ebberts
Re: Changing Color Overlay at keyframes?
on Apr 15, 2011 at 10:49:57 pm
This should get you close. It starts with dark blue and eases to the other layer's color between the first and second keyframes. It doesn't do anything if there are less than two keyframes.
startColor = [0,0,.5,1];
endColor = comp("SETTINGS").layer("BLUE").layerStyle.colorOverlay.color;
if (numKeys > 1){
t1 = key(1).time;
t2 = key(2).time;
ease(time,t1,t2,startColor,endColor)
}else
value
Dan
Josh Pigford
on Apr 16, 2011 at 3:02:43 am
That's perfect Dan, thanks!
