Parent Y-scale to a slider
COW Forums : Adobe After Effects Expressions
S.J. DeLuise
on Mar 30, 2011 at 1:25:21 am
I'm trying to use this expression to parent only the y-scale of a layer to a slider.
But I'm getting this:
"Bad argument: index 1 out of range for stream of dimension 1, Expression disabled."
It works fine for x-only when I change it to this:
[temp[0], value[1]];
Why?
temp = thisComp.layer("Null 3").effect("Slider Control")("Slider");
[value[0], temp[1]];
People say my motion graphics are moving.
Dan Ebberts
Re: Parent Y-scale to a slider
on Mar 30, 2011 at 1:36:47 am
You're trying to extract a second dimension from a value that only has one (the slider). Try it this way:
[value[0], temp];
Dan
S.J. DeLuise
on Mar 30, 2011 at 1:39:53 am
Yup, that worked.
S.J. DeLuise
on Mar 30, 2011 at 1:44:10 am
Actually I thought that was the whole issue, but now I'm hitting another snag when I try to use an audio-to-keyframes layer to control the value of Y-scale.
error: "Expression result must be of dimension 2, not 1"
a = thisComp.layer("audio").effect("Both Channels")("Slider");
[value[0], a];
linear(a, 0, 12, 100, 112);
Dan Ebberts
on Mar 30, 2011 at 2:33:09 am
I think this is what you want:
y = linear(a, 0, 12, 100, 112);
[value[0], y];
Dan
S.J. DeLuise
on Mar 30, 2011 at 3:12:53 am
Worked great!
Thanks again, Dan.
Robert Roebke
on Mar 21, 2017 at 4:00:55 pm
Hey Dan,
what if i want to Parent X-Scale AND Y-Scale to a different Slider? I couldn't figure it out.
Would be great to hear from you!
Thanks in advance,
Rob
Dan Ebberts
on Mar 21, 2017 at 5:07:18 pm
Something like this should work:
x = thisComp.layer("Your Layer").effect("Slider Control X")("Slider");
y = thisComp.layer("Your Layer").effect("Slider Control Y")("Slider");
[x,y]
Dan
Robert Roebke
on Mar 22, 2017 at 1:48:25 pm
Thank you very much!
One more question - how could i define the anchor point / postion from where it should scale...? 😳
Dan Ebberts
on Mar 22, 2017 at 5:40:22 pm
You'd need an expression for the Anchor Point (and possibly a compensating Position expression, if you don't want the layer to move when you change the Anchor Point).
Dan
