Per Character Bounce Scale
COW Forums : Adobe After Effects Expressions
Sal Joseph
on Mar 23, 2011 at 8:05:27 pm
I've seen this effect recently on a tv commercial.
It's similar to the effect you would create by adding a text animator for Scale, Based on Character, Randomize Order ON, and keyframing the range start from 0-100%.
Only each character had a Spring/Bounce to it.
Essentially, it's THIS effect put on each character of a word, scaling in random order:
freq =3;
amplitude = -100;
decay = 1.0;
s = amplitude*Math.cos(freq*time*2*Math.PI)/Math.exp(decay*time);
scale + [s,s]
I'm assuming there's a way to do this without having the expression on a layer for each character (otherwise I applaud that animator's patience).
I tried combining expressions with a Text animator. But maybe that's the wrong approach.
Dan Ebberts
Re: Per Character Bounce Scale
on Mar 23, 2011 at 10:14:16 pm
Play with this:
Add a Scale Animator, set the Scale value to 0. And an Expression Selector, delete the Range Selector, and add this expression to the Expression Selector's Amount parameter:
maxDelay = 2;
seedRandom(textIndex,true);
myDelay = random(maxDelay);
t = time - myDelay;
if (t >= 0){
freq =3;
amplitude = -100;
decay = 1.0;
s = amplitude*Math.cos(freq*t*2*Math.PI)/Math.exp(decay*t);
[s,s]
}else{
value
Dan
Sal Joseph
on Mar 23, 2011 at 11:45:06 pm
Incredible. Works perfectly.
Thank you again!
Sal Joseph
on Mar 24, 2011 at 12:03:33 am
Also, just noticing that an amplitude of +100 makes the characters grow from 0, whereas an amplitude of -100 causes them to pop on.
S.J. DeLuise
on Jul 12, 2011 at 3:55:07 pm
Could this expression selector be applied to other expressions? For instance if I wanted the characters (or words) to bounce in one at a time using the bounce expression seen below. Is it a simple matter of switching the 'if' condition to that bounce expression?
I tried but I think I'm missing something, maybe on another parameter.
//BOUNCE EXPRESSION
freq = 1.0; //oscillations per second
amplitude = 90;
decay = .5;
posCos = Math.abs(Math.cos(freq*time*2*Math.PI));
y = amplitude*posCos/Math.exp(decay*time);
position - [0,y]
//MODIFIED EXPRESSION SELECTOR
maxDelay = 2;
t = time - myDelay;
if (t >= 0){
amplitude = 90;
decay = .5;
posCos = Math.abs(Math.cos(freq*t*2*Math.PI));
y = amplitude*posCos/Math.exp(decay*t);
position - [0,y]
} else {
value
People say my motion graphics are moving.
Dan Ebberts
on Jul 12, 2011 at 5:00:55 pm
Set the y component of your Position animator to the maximum value you want. Then try this in the Expression Selector:
maxDelay = 2;
t = time - myDelay;
if (t >= 0){
amplitude = 100;
decay = .5;
} else {
value
Dan
S.J. DeLuise
on Jul 12, 2011 at 5:11:19 pm
Works great!
Is there any way to do this by word rather than by character?
Very cool. Sure beats having a layer for every letter.
Would this work for Y-rotations per letter, like a Wheel of Fortune reveal, etc.?
Dan Ebberts
on Jul 12, 2011 at 5:27:56 pm
In the Expression Selector, just change Based On to "Words".
>Would this work for Y-rotations per letter?
Yes.
Dan
S.J. DeLuise
on Jul 12, 2011 at 5:49:04 pm
Ah, yes. That parameter was temporarily hidden for me.
So many possibilities. Thank again, Dan.
Your code is simple amazing - kudos.
S.J. DeLuise
on Jul 13, 2011 at 1:40:51 am
Examples from playing around with these awesomely nifty codes:
Charlie Aquino
on Aug 18, 2011 at 9:44:01 am
Thanks a lot for this. It helped a lot.
But just a question. What if you don't want the animation to be random, how do we modify the expression?
Thanks a lot!
Dan Ebberts
on Aug 18, 2011 at 1:52:23 pm
Did you just want a delay that increases for each character? That would look like this:
delay = .1;
myDelay = delay*textIndex;
t = (time - inPoint) - myDelay;
if (t >= 0){
freq =3;
amplitude = -100;
decay = 1.0;
[s,s]
}else{
value
Dan
Charlie Aquino
on Aug 18, 2011 at 4:51:22 pm
Superb! Thanks Dan.
Jake Williams
on Jun 24, 2013 at 3:55:25 am
Great expressions Dan!
I've been tweaking the expression to attempt to get a "Back" sort of animation where a word starts at 0, overshoots it's scale, then settles back at it's regular size. Would there be a way to tweak the expression so that it only does the one motion and stops bouncing?
-Jake
Dan Ebberts
on Jun 24, 2013 at 4:19:57 am
I'd say start with something like this:
delay = .1;
if (t >= 0){
freq =2;
amplitude = -200;
decay = 15;
s = amplitude*Math.sin(freq*t*2*Math.PI)/Math.exp(decay*t);
[s,s]
}else{
value
Dan
Jake Williams
on Jun 24, 2013 at 2:58:00 pm
Thanks Dan, this is a great place to start. I think I can tweak it from here!
Much appreciated.
-Jake
Andrea Digiorgio
on Oct 18, 2013 at 3:16:31 pm
Hi, i have a question about. I used it for "animate in" a word and it works, is there a way to "animate out"? I tried but maybe i don't know what is the parameter to set.
Federico Cocheo Filetti
on Oct 19, 2013 at 8:42:15 am
You have to duplicate the entire animator and then all you need to do is change the the "t" variable from:"t = (time - inPoint) - myDelay;"
to "t = (outPoint - myDelay) - time;".
Hope it helped! :P
Chad Shack
on Jan 8, 2014 at 3:50:23 pm
I've tried applying the expression as mentioned above and am getting no action what so ever. I have attached a screen grab of the simple set up as described. What have I missed in setting this up?
Chad
Dan Ebberts
on Jan 8, 2014 at 6:15:23 pm
For scale, I think you'd want something more like the second expression in the Calculation Overshoot section of this article:
http://www.motionscript.com/articles/bounce-and-overshoot.html#calc-oversho...
Dan
Jaqai Mickelsen
on Nov 5, 2014 at 1:19:39 pm
This string has been an amazing help. So, two things.
First, thank you very much. I'm waaaaay closer now than I was when I started, all thanks to you.
Second, in the digging I've done around these here internets, to use an expression with text animators, you're pretty much getting rid of the range selector. I'm curious to know if there's a way to have the best of both worlds?
In short, I'm matching the words up with what is being said by a voiceover, so I'd love to be able to get in there and tweak the timing for "per word bounce out" alignment.
Think William Shatner as Captain Kirk delivering a line. Is there a way to easily align the triggers for each word's bounce out animation to align with when it's being said?
Dan Ebberts
on Nov 5, 2014 at 2:37:00 pm
You could try something like this to time the reveal of each word with layer markers:
freq = 3;
decay = 5;
startVal = [100,100];
endVal = [0,0];
dur = 0.1;
try{
t = time - marker.key(textIndex).time;
}catch (err){
t = 0;
if (t > 5){
endVal
}else if (t > 0){
if (t < dur){
linear(t,0,dur,startVal,endVal);
}else{
amp = (endVal - startVal)/dur;
w = freq*Math.PI*2;
endVal + amp*(Math.sin((t-dur)*w)/Math.exp(decay*(t-dur))/w);
}else
startVal
Dan
Jaqai Mickelsen
on Nov 5, 2014 at 4:18:51 pm
Perfect! My goodness. I feel like every After Effects user needs to work together on getting a statue erected in your in your honor. You just saved me a ridiculous amount of time.
Thank you VERY much.
Stacy Obakpolor
on Oct 15, 2015 at 8:20:01 pm
Thank you so much for all your help!! This will save me a tremendous amount of time. You're a saint.
