Applying expressions via a script - problems with variables
COW Forums : Adobe After Effects Expressions
Simon Björk
on Jan 4, 2011 at 9:45:58 am
Say I have the following script.
var myComp = app.project.acitveItem;
var myCamera = myComp.layer(1);
var myLayer = myComp.layer(2);
and I want to connect the rotation of my layer to the rotation of my camera. For that example,
myLayer.rotation.expression = "thisComp.layer("Camera 1").transform.zRotation";
would work I guess. But what if I don't know that the camera name is "Camera 1"? Is it possible to use the variable myCamera somehow? I mean, for example it would be easy if I could say: myLayer.rotation.expression = "myCamera.transform.zRotation";. But that doesn't work.
So my question is if it's possible to use variables set in scripting to your expressions?
Dan Ebberts
Re: Applying expressions via a script - problems with variables
on Jan 4, 2011 at 4:11:44 pm
In your example, is myCamera a variable within your script that holds the name of a camera? If so, this should work:
myLayer.rotation.expression = myCamera + ".transform.zRotation";
Dan
