Animating between two position values with a Slider?
COW Forums : Adobe After Effects Expressions
Jordan Montreuil
on Dec 28, 2010 at 8:06:50 pm
I am working on a shot that includes the Advanced Lightning effect. The Lightning needs to grow from one point to another. I have the Origin and Direction linked to two separate nulls that are then animated so that they follow the position of objects in the video.
Is there a way that I can link the Direction parameter to a percentage slider where 0% is the position of one null and 100% is the position of a second null? The ideal result would be being able to animate between the two positions while they themselves are being animating to follow some video.
Chris Wright
Re: Animating between two position values with a Slider?
on Dec 28, 2010 at 9:41:12 pm
if you want it variably controlled, I don't see why a linear wouldn't work.
//paste in direction and slider will control balance between 2 nulls.
s = effect("Slider Control")("Slider");
x=thisComp.layer("Null 1").transform.position;
y=thisComp.layer("Null 2").transform.position;
n1=x[0];
n2=x[1];
n3=y[0];
n4=y[1];
s1=linear(s, 0,100, n1, n3);
s2=linear(s, 0,100, n2, n4);
[s1,s2];
//you can also add wiggle in slider if you want.
http://technicolorsoftware.hostzi.com/
Jordan Montreuil
on Dec 29, 2010 at 8:35:54 pm
Beautiful. If I could email you a cookie, I would.
Marc Ger
on Dec 15, 2014 at 5:42:39 pm
How would you utilize this in a 3D environment? I tried modifying the expression a few different ways but wasn't able to get it to work.
Dan Ebberts
on Dec 15, 2014 at 7:06:44 pm
This should work:
p1=thisComp.layer("Null 1").transform.position;
p2=thisComp.layer("Null 2").transform.position;
linear(s,0,100,p1,p2)
Dan
