increment text layer
COW Forums : Adobe After Effects Expressions
Nick Leigh
on Nov 30, 2010 at 8:16:38 pm
Ok I give up. I have been search the forum and expression examples for a couple hours now and can't figure out how to increment a text layer when certain conditions are met.
I have markers set on a null layer that tells me at what time goals were scored in a hockey game. So I want to increment up by one when I hit a marker when time = the marker time and the marker comment = 3. I have seen though debugging that I am getting inside the condition statement to increment up but for some reason it isn't working. This expression is in the text layer I am trying to increment.
I posted the expression I have so far with no luck.
Thanks for any help.
Nick
if (time > 0)
curScore = parseInt(thisComp.layer("Away Score").text.sourceText);
c = thisComp.layer("Game Markers");
n = c.marker.nearestKey(time).index;
if (c.marker.key(n).time == time && c.marker.key(n).comment == 3)
home = curScore + 1;
else
home = curScore;
//home = 'key:'+n+', cur:'+time+', keytime:'+c.marker.key(n).time+', comment:'+c.marker.key(n).comment+',score:'+
else
home = 0;
home;
Nick Leigh
Re: increment text layer
on Nov 30, 2010 at 8:30:22 pm
I decided to do this a different way just counting the markers that met the conditions.
if (time > 0)
count = 0;
if (c.marker.key(n).time > time) n--;
// loop thru
for (i = n; i > 0; i--)
if (c.marker.key(i).comment == 3)
count++;
else
count = 0;
away = count;
But would still like to know how to increment if it is at all possible.
Dan Ebberts
on Nov 30, 2010 at 10:15:05 pm
I think I know what you're getting at, but you can't do it that way. Expressions have no memory and have no access to values they calculated on previous frames. So you can't just increment a previous value, you have to recalculate it first.
Dan
Dan Ebberts
on Nov 30, 2010 at 8:31:44 pm
Here's the basic idea:
count = 0;
for (i = 1; i <= c.marker.numKeys; i++){
if (c.marker.key(i).time > time) break;
if (c.marker.key(i).comment == "3") count++;
count
Dan
Navarro Parker
on Jun 13, 2013 at 8:56:58 pm
I'm having trouble getting this to work.
My layer markers are on the same text layer as the expression. But the starting number isn't incrementing when it hits a marker.
c = thisLayer;
count = 10;
count
Dan Ebberts
on Jun 13, 2013 at 9:02:41 pm
It only counts markers that have a comment of "3" (without the quotes). Did you want it to count all the markers? You could do that this way:
c = thisLayer;
count = 10;
count++;
count
Although, if that's what you want, you could just get the index of the most recent, previous marker and add that to count.
Dan
Navarro Parker
on Jun 13, 2013 at 9:12:53 pm
Sure... why not use the index! :)
Navarro Parker
on Jun 13, 2013 at 9:41:02 pm
And how about decrementing by -1?
