Random number from array to target layer
COW Forums : Adobe After Effects Expressions
David Wiffen
on Nov 22, 2010 at 4:18:28 pm
Hi Everyone,
Ok hopefully this is simple enough. Here's my expression...
posx = thisComp.layer("Emitter.2").transform.position[0];
posy = thisComp.layer("Emitter.2").transform.position.wiggle(thisComp.layer("WiggleEmitter").effect("Freq")("Slider"),thisComp.layer("WiggleEmitter").effect("Amp")("Slider"))[1];
[posx,posy];
All I want to do is where it references "Emitter.2" I want to have an expression that says randomly select an number from an array of x amount and apply to this reference. So when I duplicate the layer up it will pick a different number each time.
Eg. Emitter.1 / Emitter.2 / Emitter.3 / Emitter.2/ Emitter.1 / Emitter.3 and so on...
Hope that makes sense!
Dan Ebberts
Re: Random number from array to target layer
on Nov 22, 2010 at 4:59:20 pm
This would be one way to randomize references to the 3 layers:
seedRandom(index,true);
n = Math.floor(random(3)) + 1;
emitterName = "Emitter." + n;
posx = thisComp.layer(emitterName).transform.position[0];
Dan
David Wiffen
on Nov 22, 2010 at 5:15:41 pm
Very impressive - Thanks Dan!
One more question...If I have other expressions on the same layer that I want to have the same value as what the random expression chooses...how would I do that?
eg.
This is on position x and y and works great:
emitterName = "Emitter0" + n;
posy = thisComp.layer(emitterName).transform.position.wiggle(thisComp.layer("WiggleEmitter").effect("Freq")("Slider"),thisComp.layer("WiggleEmitter").effect("Amp")("Slider"))[1];
[posx, posy] - value + wiggle(thisComp.layer("WiggleEmitter").effect("Freq")("Slider"),thisComp.layer("WiggleEmitter").effect("Amp")("Slider"));
This is on the z and needs to have the same random value as the x and y have for the emitter number:
thisComp.layer(emitterName).transform.position[2];
thanks again Dan - you're talented guy!
Dan Ebberts
on Nov 22, 2010 at 8:07:25 pm
You'd have to put the random calculation on a slider control and have both expressions pick it up from there. The expression on the slider would just be:
Dan
Lloyd Alvarez
on Nov 22, 2010 at 9:28:43 pm
You could add a slider control and generate the random number there then have X and Z get the number from there.
This is the code you should put on the slider control:
And this would be the updated code for Z:
n=effect("Slider Control")("Slider").value;
-Lloyd
http://aescripts.com
David Wiffen
on Nov 23, 2010 at 9:20:34 am
Brilliant - thanks Both!
Really really appreciate it!
