Expression for Digital 24 Hours clock
COW Forums : Adobe After Effects Expressions
gilben
on Oct 14, 2005 at 1:02:05 pm
I am looking for a smarter way to build a count down 24 hours clock.
I couldnt find the right plugin for this (the text number effect - is not good for 24 hours count down and has no 100/th of a sec.)
Doing this with key frames seem to me no too effecient.
I was thinking maybe anyone of you is familiar with plug in or if it could be done with animation Expression.
Tnx for any help
Gil
Dan Ebberts
Re: Expression for Digital 24 Hours clock
on Oct 14, 2005 at 5:30:51 pm
24 hour count down clock (expression for text layer source text):
// 24 hour count down clock
beginHr = 23;
beginMin = 59;
beginSec = 59;
beginHun = 0;
beginTime = (beginHr*60 + beginMin)*60 + beginMin + beginHun/100;
function digits(myVal,myNumDigits){
var s = myVal.toString();
while (s.length < myNumDigits) s = '0' + s;
return s;
currTime = beginTime - time;
hr = digits(Math.floor(currTime/3600),2);
min = digits(Math.floor((currTime%3600)/60),2);
sec = digits(Math.floor(currTime)%60,2);
hun = digits(Math.floor(currTime%1*100),2);
hr + ":" + min + ":" + sec + "." + hun
Dan
Dan Ebberts
Re: Expression for Digital 24 Hours clock - oops
on Oct 14, 2005 at 6:22:50 pm
You'd think I'd have learned by now to always try it before posting. This should work better:
beginHr = 3;
beginMin = 0;
beginSec = 1;
beginHun = 0;
beginTime = (beginHr*60 + beginMin)*60 + beginSec + beginHun/100;
return s;
Dan
gilben
on Oct 15, 2005 at 8:02:53 am
Dan
Thank you very vewry much for your serious respond.
i will try it your way
i quess i should take some tutorials in expression methods.
thanx alot.
Gil
Brandon McFarland
on Aug 25, 2011 at 7:08:15 pm
I'm trying to modify this to make a 48 hour countdown. I've got the numbers correct, but I want to try and get the numbers under 10 to display with a zero in front of them. Any tips for that? I tried just changing the begin values, but that didn't work at all (it didn't mess up the expression at all though, so I left it).
Thanks.
beginHr = 48;
beginMin = 00;
beginSec = 00;
beginHun = 00;
while (s.length) return s;
Dan Ebberts
on Aug 25, 2011 at 7:53:46 pm
You didn't get the whole expression. Try this:
beginHr = 48;
beginMin = 0;
beginSec = 0;
beginHun = 0;
while (s.length < myNumDigits) s = "0" + s;
return s;
Dan
Brandon McFarland
on Aug 25, 2011 at 7:57:22 pm
That works. Thanks! Now I just have to find a fixed width font that looks decent so it doesn't look like it's jumping around as much.
Gordon Fales
on Sep 23, 2011 at 3:24:13 am
thanks for posting this.
I want to do the same thing but be able to set a key frame and run it not in real time. For example 20 hours down to 0 in 30 seconds.
Thanks for you help
Dan Ebberts
on Sep 23, 2011 at 6:25:34 am
I'm not sure what you want to keyframe, but to run it faster than real time, you just need to add a rate variable, like this:
rate = 2400;
beginHr = 20
beginMin = 0;
beginSec = 0;
beginHun = 0;
return s;
currTime = beginTime - time*rate;
That should count down 20 hours in 30 seconds.
Dan
Gordon Fales
on Sep 28, 2011 at 6:38:43 pm
Dan
Thanks so much for your help I may have an easy job for you
Thanks so much
Gordon
gfales@sbcglobal.net
Gordon Fales
on Sep 28, 2011 at 7:04:53 pm
Dan
will you send me an email?
Gordon
Sara Martinez
on Nov 12, 2016 at 9:55:09 pm
Hi Dan Ebberts/everyone.
I am trying to figure our an expression for DAYS: HOURS: MINUTES: SECONDS countdown. I have been playing with the codes Dan provides but I don't really know that much about expressions and I cannot figure it out. Dan's expressions work like a charm but are for other types of countdowns (most without days). Could you help me find an expression for this if there is one or help me figure out how to accomplish this?
Thank you!!!
Will Gallow
on Nov 19, 2016 at 8:12:33 am
Hello Sara,
You can try my preset Counter Pro, to create easily timers and countdowns ?
It's free : http://www.guillaumegallot.fr/tools/counter-pro
MatthewB
on Mar 13, 2006 at 4:18:01 am
Dan/Anyone
what is taking place here in your expression:
return s;
i can follow the rest but am having trouble with what "function" is performing (adobe help, wasnt) then waht is the digits command accomplishing... s i take it is getting the length of myVal
i think i can figure it from there... just am not sure what is happening at the beginning...
i have to write a clock that starts at a specific point and stops at a specific point over a specified period... i.e. clock starts at 30.0 seconds and over 2 second climb to 43.14 seconds.
thanks,
