Link to another color and adjust it
COW Forums : Adobe After Effects Expressions
Nate Vander Plas
on Jun 14, 2010 at 8:17:00 pm
I'm trying to figure out a way to link one color to another and then adjust that original color with an expression. Obviously it's easy to link one color property to another color property with the pick whip, but I then want to adjust the hue (and maybe the lightness, saturation, and alpha) of that original color. For instance, if the original color is blue, I'd like to automatically transform the new color to something complimentary, like orange. I've seen some stuff on hslToRgb, but was unsuccessful with adapting that to my situation. I'm working in CS3, if that matters.
Nate
Dan Ebberts
Re: Link to another color and adjust it
on Jun 14, 2010 at 9:01:50 pm
I'm not quite sure what you're after, but this example would invert the color of the fill effect applied to another layer (named "master" in this example):
c = thisComp.layer("master").effect("Fill")("Color");
[1-c[0],1-c[1],1-c[2],c[3]]
Dan
Filip Vandueren
on Jun 15, 2010 at 1:02:08 am
Or, if you just want to invert the hue:
hsl = rgbToHsl(c);
hue = (hsl[0]+0.5)%1;
compl = [hue, hsl[1], hsl[2], hsl[3]];
hslToRgb(compl);
this will get the color that is 0.5 or 180° across on the color wheel, but with the same saturation, brightness and alpha as the master.
Nate Vander Plas
on Jun 17, 2010 at 7:01:18 pm
Thanks guys! That's what I was looking for Filip!
Stephen Botting
on Sep 22, 2010 at 8:25:17 pm
Hi there,
I'm trying to do a similar thing but through extendscript, when I try to run it says that "Function hslToRgb is undefined"
Stephen
var inRgb = hslToRgb([0.5,0.5,0.5,0]);
http://www.43south.co.nz
Dan Ebberts
on Sep 22, 2010 at 8:32:57 pm
Scripting doesn't have that function. I've seen the algorithm around somewhere -- it shouldn't be too hard to implement your own conversion function. Or, you could create a temporary layer, apply an expression that does the conversion, harvest the result, and delete the layer.
Dan
Stephen Botting
on Sep 22, 2010 at 10:00:05 pm
Thanks Dan,
As you suggested I found a page with an algorithm to make the conversion.
When I try to run the script I wrote I get returned the error "| is undefined" with the line "if (S == 0) {" highlighted, if I comment out that "if" structure, I get the same error but on the "var rgb = new Array(3);"
Any suggestions?
Stephen
For some reason all my < symbols are appearing as < tried to fix it and it changes back.
function hslToRGB(H,S,L) {
//http://130.116.54.154/~monger/hsl-rgb.html
if (S == 0) {
rgb[0] = L;
rgb[1] = L;
rgb[2] = L;
return rgb;
if (L &lt; 0.5) var temp2 = L * (1.0+S);
if (l >= 0.5) var temp2 = L+S-L*S;
var temp1 = 2.0*L - temp2;
H = H/360;
var temp3 = new Array(3);
temp3[0] = H+1.0/3.0;
temp3[1] = H;
temp3[2] = H-1.0/3.0;
for (i=0; i &lt; temp3.length; i++) {
if (temp3[i] &lt; 0) temp3[i] = temp3[i] + 1.0;
if (temp3[i] > 1) temp3[i] = temp3[i] - 1.0;
if (6.0 * temp3[i] &lt; 1) {
rgb[i] = temp1 +(temp2-temp1) * 6.0 * temp3[i];
} else if (2.0*temp3[i] &lt; 1) {
rgb[i] = temp2;
} else if (3.0*temp3[i] &lt; 2) {
rgb[i] = temp1+(temp2-temp1)*((2.0/3.0)-temp3[i])*6.0;
} else {
rgb[i] = temp1;
return rgb;
Dan Ebberts
on Sep 22, 2010 at 10:53:35 pm
This line is causing the problem:
It should be
if (L >= 0.5) var temp2 = L+S-L*S;
Dan
Ivan Zornic
on May 5, 2017 at 3:17:35 pm
Hi there,
I know that this tread is bit old but I couldn't find inverse function: RgbToHsl().
I have created JS copy of function provided here:
http://wiki.secondlife.com/wiki/Color_conversion_scripts#RGB_to_HSL
but it returns some strange values.
Any help will be appreciated.
function RgbToHsl(rgb){
var r = rgb[0] / 255;
var g = rgb[1] / 255;
var b = rgb[2] / 255;
var h;
var s;
var l;
var max;
var min;
// Looking for the max value among r, g and b
if (r > g && r > b) max= r;
else if (g > b) max = g;
else max = b;
// Looking for the min value among r, g and b
if (r &lt; g && r &lt; b) min = r;
else if (g &lt; b) min = g;
else min = b;
l = (max + min) / 2;
if (max == min){
h = 0.0;
s = 0.0;
}else{
var d = max - min;
if (l > 0.5) s = d / (2 - max - min);
else s = d / (max + min);
if (max == r) {
if (g &lt; b) h = (g - b) / d + 6;
else h = (g - b) / d;
else if (max == g)
h = (b - r) / d + 2;
else
h = (r - g) / d + 4;
h /= 6;
return [h, s, l];
