Unknown closed caption format
COW Forums : Broadcasting
Jiri Fiala
on Nov 30, 2018 at 4:24:04 pm
Hello,
I got a closed caption file that I need to convert to SRT in order to burn it into image with Final Cut Pro X. The issue is, I don't know this file structure and I can't open it in any subtitle editor.
Structure looks like this:-------------------
10:01:18:22 10:01:22:10 03:13
text1
10:01:22:10 10:01:26:03 03:18
text2
10:01:55:24 10:01:58:09 02:10
text3
Any clues as to how to convert this into SRT? Many thanks!
Bouke Vahl
Re: Unknown closed caption format
on Nov 30, 2018 at 11:20:01 pm
I bet Subbits can open it.
https://www.videotoolshed.com/product/subbits-subtitler/
Don't forget to set the framerate correct before making an attempt.
Bouke
http://www.videotoolshed.com
Jiri Fiala
on Dec 1, 2018 at 9:15:52 am
Only as plain text. I give up and will probably copy/paste in NLE by hand. Thanks for the tip though, that looks like a superb subtitler.
Bouke Vahl
on Dec 1, 2018 at 9:52:04 am
I don't get it. It IS plain text, isn't it?
If you need to do a 'save as', that will be two mouse clicks...
Send me the file and I'll have a look.
Bouke
Jiri Fiala
on Dec 1, 2018 at 9:57:15 am
What I need is to convert it to .srt in order to bring it into NLE to hardcode into the video (I really don't want to do copy/paste and time it manually in the NLE). For that, I need to know what the source format is. It's apparently some kind of CC format used by a broadcaster (it's SIMILAR to SRT but different) but what I got only has a .txt extension.
Here's the file.
https://www.dropbox.com/s/ut42k4w41s2a9nb/venkov%208_18%20ENG.txt?dl=0
Thanks for your help.
Bouke Vahl
on Dec 1, 2018 at 6:22:58 pm
It is NOT similar to SRT.
Srt has milliseconds instead of frames, is tab delimited, has no duration and some more stuff.
This has TC in / out and duration, followed by the text. Probably this was outputted for proof reading / spellcheck. (That did not happen, as I found some mistakes I believe ☺
I've converted the file to SRT, assuming 25 fps speed.
Bouke
Bouke Vahl
on Dec 1, 2018 at 7:12:55 pm
Perhaps this might help...
Download link:
https://we.tl/t-XDlc09c3DV
Bouke
Jiri Fiala
on Dec 2, 2018 at 9:08:14 am
Oh my gosh, how did you convert it? Thank you so much!
Bouke Vahl
on Dec 2, 2018 at 10:03:46 am
I added a new text parser to Subbits, wasn't that difficult.
(Note, it is not available in the public version yet, if you need to do tons more, let me know.)
Bouke
Jiri Fiala
on Dec 2, 2018 at 10:29:43 am
I don't at the moment, but I've added Subbits to my Tools list and I'll probably buy it down the line. Thanks again!
Nathaniel Deshpande
on Jan 31, 2019 at 6:54:58 pm
If this is still an issue you should reach out to Closed Caption Creator (https://www.closedcaptioncreator). They'll add the format to their list of supported formats to do the conversion to SRT for you.
