What's the best practice for streamlining uploading to multiple broadcasters?
COW Forums : Broadcasting
Stephen Pickering
on Mar 14, 2014 at 8:49:18 pm
Hi there,
I've been asked to upload a 30 second spot to about 15 different broadcasters (most with FTP, thank goodness). I'm wondering if there is a streamlined workflow or a best practice I should be following. Some request 1080i while others request 720p, and then there's mpg, mov, and h.264.
Is there a workflow I should use or do I just make 10 different (or however many) presets in my encoder (I'm using Premier Pro with Adobe Media Encoder) and then upload each file via ftp as I check them off the list?
Thanks for any advice!
-Stephen Pickering
Tanvir Hossain
Re: What's the best practice for streamlining uploading to multiple broadcasters?
on Aug 9, 2014 at 3:23:34 pm
Video Cloud is designed to simplify the process of publishing your videos so that your single upload plays beautifully on the desktop, mobile device, and connected TV, no matter the content, resolution, or connection speed.
Tanvir Hossain
weddingtropics.com/, individualcareoftx.com
