Achieving 150 Mbps
COW Forums : Broadcasting
Raja Osama
Achieving 150 Mbps
on Jan 24, 2014 at 9:12:40 pm
Hi everyone,
I've produced a commercial, the broadcast specs required are:
File format MPEG-2 elementary stream (.m2v file)
Profile and level 4:2:2Profile@HighLevel (422P@HL)
Bitrate 150 Mbps constant bitrate (CBR)
GOP structure I-frames only (GOP size (N) = 1, M = 1)
Sequence header On each GOP
First GOP Closed
Timecode Starting at 00:00:00:00 and increasing continuously
I'm using Adobe Media Encoder CC. The problem I'm having is that the maximum bitrate it would allow me in M2V format is 80 Mbps, which is almost half of what is required.
Can anyone please share a word, I'd really appreciate.
Thanks in advance,
Osama
Thomas Nord
Re: Achieving 150 Mbps
on Jan 31, 2014 at 6:17:55 am
Please make sure you have updated to the latest version of AME. This was a bug we fixed in version 7.1.
Alex Gerulaitis
on Jan 31, 2014 at 7:50:58 am
Was the bug fixed in CS6 by any chance?
Thomas Nord
on Jan 31, 2014 at 6:11:42 pm
The bug was introduced early in the CC cycle and did not exist in CS6. You should be able to create a 4:2:2/High 150+ Mbps file using AME CS6.
Alex Gerulaitis
on Jan 31, 2014 at 8:03:46 pm
Thanks. I am on CS6 and couldn't get bitrates go past 80 and in some cases 50 and 40Mbs on MPEG and H.264 files. I'll try it again.
Thomas Nord
on Jan 31, 2014 at 8:07:40 pm
The available bitrate is determined by the Level/Profile you have selected. If you select 4:2:2/High you will be able to get up to 300 Mbps.
