Connecting a calibrated monitor to a 2006 Imac
COW Forums : Broadcasting
Francisco Bech Gómez
on Mar 25, 2013 at 11:40:47 am
Hello, is there any possible way to use a calibrated external monitor with an imac from 2006?, no thunderbolt in the imac, only usb and firewire connections
The problem is I want to grade some red one footage, I tried first calibrating the Imac screen with Spyder pro 3, a calbrating screen tool to work with photographs. But, when I play the DVD on a TV, the footage looks very bright compared to what I see in my imac screen. So I guess, I need to do this color grading using a real calibrated monitor. I am out of budget to go to a post production facillity etc.
Tom Matthies
Re: Connecting a calibrated monitor to a 2006 Imac
on May 9, 2013 at 12:53:10 pm
You could try using an AJA IoHD, but that will require a Firewire 800 connection. Not sure if FW800 is in that old of a machine.
E=MC2+/-2db
