Blackburst generator for HD. Advice?
COW Forums : Broadcasting
Gautam Pandey
on Jan 11, 2013 at 10:29:11 am
Recently while trying to output a HD project onto HDCAM I needed to use print to tape to be frame accurate. As it turned out kept dropping audio every few seconds. I am using the HDW D1800 Deck - http://pro.sony.com/bbsc/ssr/product-HDWD1800/
Went through the manual of the deck and couldn't really find anything
Google'd it... Found that I need to give a ref through a blackburst generator
Found these options for generators-
a Horita blackburst generator http://www.bhphotovideo.com/c/product/108433-REG/Horita_BG50_BG_50_Black_Bu.....
and a Blackmagic one http://www.bhphotovideo.com/c/product/558912-REG/Blackmagic_Design_CONVMSYN.....
Just as I'm begining to feel good I find this post http://forums.creativecow.net/thread/124/871960#871960
Now I'm confused, Is the camera solution just a workaround?
Also the product specs of the generators show they generate a SD blackburst, Is that good enough for a ref for a HD project?
My system specs are -
Mac OS X
Version 10.6.3
Processor 2 x 2.8GHz Quad-Core Intel Xeon
Memory: 6 GB 667MHZ DDR2 FB-DIMM
FCP 7.0.3
Blackmagic DeckLink HD Extreme
Version 9.5.3
Thanks guys!
Gautam Pandey
http://www.riverbankstudios.com
Tom Matthies
Re: Blackburst generator for HD. Advice?
on Jan 17, 2013 at 7:23:50 pm
AJA Gen-10. Normal and Tri-sync and fairly cheap to boot.
E=MC2+/-2db
