upconvert ntsc dftc to 23.98psf frame accurately?
COW Forums : Broadcasting
Kurt Outwater
on Apr 28, 2012 at 12:27:30 am
I'm trying to accomplish this with a panasonic ufc-1800. Is it possible to do this? With NDFTC there seems to be no issue but there is a TC offset when using dftc from the master tape. I'm taking the pulldown out of the ntsc master as well.
Any thoughts would be greatly appreciated!
John Heagy
Re: upconvert ntsc dftc to 23.98psf frame accurately?
on May 1, 2012 at 3:25:15 am
If you start the conversion on an even second the two should match. Otherwise it will be offset but should not drift.
Kurt Outwater
on May 1, 2012 at 6:01:20 am
it's a two step process with the ufc.... convert with an edit dub to ndftc then do the conversion.
John Heagy
on May 3, 2012 at 9:05:52 pm
Oh I see now. There is no such thing as ndtc 23.98 so it will be impossible for it to match your dftc 60i master.
