Broadcast standards for a commercial?
COW Forums : Broadcasting
Keith Goldstein
on Mar 13, 2012 at 7:21:12 pm
We focus on web video. We usually shoot in 1080p 29.97, and send out an H.264 at that size (we edit in ProRes 422, but that file size is far too impractical for clients). Tomorrow we are shooting commercials for broadcast. Is that any kind of standard (or a general idea) that we should follow? I don't see the video being a problem, but as far as motion graphics go, should they be created at 24 fps instead of 30? The client hasn't told us anything about the delivery to the distributor, so I don't know the technical aspect on their end. Thus, I am looking more for a general rule of thumb. Any help would be great.
John Heagy
Re: Broadcast standards for a commercial?
on Mar 13, 2012 at 10:18:46 pm
You can continue to shoot in 1080p 29.97 as that is compatible with 1080i 59.94 broadcasts. Your graphics should match what you shoot and edit so they would also be 1080p 29.97.
The only reason to shoot 24p is if there are International deliverables.
John
Keith Goldstein
on Mar 13, 2012 at 10:25:28 pm
How about interlaced vs progressive? I'm afraid that creating progressive motion graphics (for approval) and then transcoding to interlaced could cause stuttering in the graphics.
John Heagy
on Mar 13, 2012 at 10:39:36 pm
No need to transcode to 1080i interlaced. 1080p 29.97 "lives" inside 1080i 59.94 just fine unaltered. Remember the frame rate of 1080i is still 29.97, the field rate is 59.94. 1080i 29.97 is a more accurate name as there are 29.97 interlaced frames per second. Fields are just two images interlaced together into a single frame. In 1080p 29.97 there is only one image and a 1080i stream really doesn't care.
John
