Broadcast Quality mpeg2 - Software to transcode?
COW Forums : Broadcasting
Aaron Villa
on Feb 14, 2012 at 8:04:44 pm
I was wondering if anyone could tell me what software out there can transcode from quicktime ProRes to high bitrate mpeg2 described below?
I have Final Cut Studio 2 suite and Adobe CS3 suite. I looked at the Apple compressor 4 manual, but all the settings for mpeg 2 are the same as the old one and only go up to 40mbps for Mpeg2. Anyone using newer CS5 to do this?
Video High Definition
• Video Codec: MPEG2
• Bit-rate: 80 Mbps; (min 50 Mbps if A/V quality approved)
• Bit-rate mode: CBR
• GOP: I frame only
• Resolution: 1920x1080
• Scanning: Progressive
• Frame Rate: 23.98 (23.976)
• Profile: 422@HL
• Aspect Ratio: 16:9
• Closed Captioning: CEA-708 NADBS
• Container: MPEG2 Transport (.ts) Preferred Program Stream (.mpg) or MXF (.mxf)
Video Standard Definition
• Bit-rate: 50 Mbps; (min 25 Mbps if A/V quality approved)
• GOP: I frame only
• Resolution: 720x480
• Scanning: Interlaced
• Frame Rate: 29.97
• Profile: 422@ML
• Aspect Ratio: 4:3
• Closed Captioning: CEA-608-B
Aaron Villa
Video Post Production | DVD Authoring | 3D Animation
aaronvilla.com
