Streaming over 4G - Bonded Cellular Solution
COW Forums : Broadcasting
Josh Haggard
on Jan 25, 2012 at 4:30:49 am
I'm looking for a solution for streaming a live broadcast to a CDN via 4G (probably Verizon's LTE).
It appears to maintain a sufficient upstream rate (2mbps min) I'll need to use a bonded cellular solution (essentially using the bandwidth from multiple USB 4G modems).
So far I've looked at:
Streambox's Avenir
TVU Network's TVPack
Mushroom Network's Streamer
LiveU's LivePack
MobileMedia's WMT
All seem to be $10,000 minium. Add on top of this bandwidth costs/limitations and things are looking pricey.
Does anyone have a suggestion for a lower cost solution?
JH
Aleksander Steffensen
Re: Streaming over 4G - Bonded Cellular Solution
on Jan 25, 2012 at 10:48:48 am
Do take a look at the Teradek Cube (http://cube.teradek.com/encoders.html), they are inexpensive (compared to the other solutions), and I believe they do what you're asking.
Steffensen Multimedia
Josh Haggard
on Jan 25, 2012 at 6:15:43 pm
Thanks, but I believe the Teradek includes mandatory encoding (which we don't want) and also only allows the connection of one modem.
Further search for bonded solutions led to the Peplink Max. It is $2000 and can bond up to 7 internet connections. It requires an additional peplink balance router which costs around $1400. The closest thing I have found so far.
Carly Smith
on Apr 1, 2012 at 4:58:26 pm
We've been looking at the Peplink as well.
Albert Patapon
on May 11, 2012 at 3:26:03 pm
Check out Aviwest's solutions !
DMNG PRO series
IBIS DMNG
snipe Transmitter
