Sony RCP 720, tally number adjustments.
COW Forums : Broadcasting
Matthew Neilon
on Nov 27, 2011 at 2:54:52 pm
I have 3 chains in use at the moment which have been scrounged from left over bits and hired in equipment. One of the cameras has always been number four when joined with the rest of our kit but in this instance it's number one.
The issue I'm struggling to get around is that the tally number is still showing as 4 on the RCP even though the camera number on the head (BVP950) is set at 1.
I can't seem to find anything useful on the internet and the manuals that I've managed to download have not helped.
the chain is a BVP-950 feeding into a CCU-550p which is being controlled by a RCP-720.
Is there anyone who might be able to offer some assistance?
Jim Main
Re: Sony RCP 720, tally number adjustments.
on May 1, 2012 at 9:27:14 pm
Hi Matthew, did you find the answer to your problem? the setting should be on a dip switch bank ion one of the cards in the ccu - at least it is in the ccu700 . if youare running rcp720 controllers, do you have the touchdown previews wired? I am having problems sourcing the connectors for these..
