Looking for.....
COW Forums : Broadcasting
Sarah Bright
Looking for.....
on Aug 11, 2011 at 1:21:26 pm
Hey, really not sure where to post this so thought I would start here...
We're setting up a new online suite and I'm looking for a monitor raiser that can turn... like this one:
http://www.tammex.com.au/store/targus-rotating-monitor-stand-awe10au-p-5445...
But one that we can get in the UK.
Can anyone help?
x
Andrew Rendell
Re: Looking for.....
on Aug 12, 2011 at 7:08:25 pm
Walter Biscardi did a good article on suite design here - http://magazine.creativecow.net/article/anatomy-of-an-edit-suite
(being in the UK his suppliers aren't appropriate over here, but great ideas to borrow from).
Question: Why do you need the riser to turn? If it's so that you can get the monitor into the right position for the seating then adjustable monitor arms, as Walter has, would do the trick (as they generally have a reasonable amount of twist in the design). If you actually need to turn a monitor regularly you'd probably be better off with a monitor turntable on a fixed height stand.
Just using Google finds a few examples of both of those things in the UK. Oh, and this is pretty similar to what you linked to - http://www.staples.co.uk/technology/computing-accessories/computer-ergonomi... although without as much turn or weight bearing capacity.
