KVM Switch w/Dual Monitor out
COW Forums : Broadcasting
Greg Burke
on Jul 11, 2011 at 7:17:38 pm
can anyone tell me a KVM switch that will support 4 inputs and 4 outputs with Dual Monitor Support?
I wear many hats.
http://www.gregburkepost.com
Walter Soyka
Re: KVM Switch w/Dual Monitor out
on Jul 11, 2011 at 7:32:14 pm
[Greg Burke] "can anyone tell me a KVM switch that will support 4 inputs and 4 outputs with Dual Monitor Support?"
What do you mean by 4 inputs and 4 outputs? This sounds more like matrix routing than a KVM.
How many dual-monitor systems do you need to connect to a single set of displays? What signals?
Walter Soyka
RenderBreak Blog - What I'm thinking when my workstation's thinking
Greg Burke
on Jul 11, 2011 at 7:36:42 pm
from what I'm Told with need 4 Avid Towers going into the Switch and up to 8 Monitors go out into rooms.
I wear many hats.
Walter Soyka
on Jul 11, 2011 at 8:07:51 pm
It doesn't just sound like you want a KVM -- you also need extension from the machine rooms to the edit rooms.
See this thread on Machine room setup [link] from the SAN forum.
It may get complicated quickly.
Walter Soyka
Gary Hazen
on Jul 11, 2011 at 10:51:19 pm
You have 4 Avid towers (A, B, C & D), all of them have dual outputs.
You have 4 rooms (edit 1, edit 2, edit 3 and edit 4).
Do you want the ability to send Avid A (both displays) to any edit room ( 1,2,3 or 4) ?
Do you simply need to to extend the DVI cables from the machine room to the edit rooms; Avid A to edit 1 and Avid B to edit 2, etc. ?
