D2 Digital Composite to SDI
COW Forums : Broadcasting
Kurt Outwater
on Feb 15, 2011 at 7:19:00 pm
I'm trying to convert the digital composite signal to SDI out of a D2 deck for migrating an archive. I realize is has a specific 4fsc signal to convert. I can't seem to find the correct device to do the conversion. Any suggestions would be much appreciated.
Andrew Rendell
Re: D2 Digital Composite to SDI
on Feb 25, 2011 at 3:00:19 pm
I used to use a Vistek "Varicomb" decoder for that. It's been a while since I've seen one though (so long that I seem to remember that the box gave us analogue YUV and making that SDI was another step, or we would go straight into a Degibeta deck's analogue component inputs). Google "comb filter decoder" and you might strike lucky.
Paul Lewis
on May 7, 2011 at 5:11:55 am
This is on ebay right now, I have no connection to the seller,
http://cgi.ebay.com/Sony-PFV-D50-Digital-Interface-w-D2-D1-Converter-/19026...
or this cheaper alternative, just have to figure out the missing power supply issue.
SER-100E Miranda
http://cgi.ebay.com/Miranda-SER-100E-4-2-2-Serial-Encoder-004-3214-/1604641...
or this AJA VIDEO SMPTE 259M PARALLEL TO SERIAL CONVERTER C10PS
http://cgi.ebay.com/AJA-VIDEO-SMPTE-259M-PARALLEL-SERIAL-CONVERTER-C10PS-/3...
I bought a set of Accom D-Bridges [a 122& a 221] to do the same thing, I never did test them, HDV kinda happened, making SD gear not so attractive.
Innovision built a box also that did D2 to D1 conversion.
Cheers,
Paul Lewis
