Knox RS 16X16 HB "re-setting"
COW Forums : Broadcasting
Joe Piazzo
on Dec 3, 2010 at 5:49:08 pm
Hi all,
Have a knox RS 16 HB switcher that intermittently re-sets itself (briefly seems to turn on and off). The settings / routes return as previously set, but it causes all 3 broadcast channels to go black for a second.
I am thinking the power supply is going. My partner here suggested that the Knox has a button battery that might be going bad - but I don't think it would then save the settings.
The problem actually began as an occasional re-set when you entered a manual swith on the front panel. Now it is doing it on the hour or so, then stops for a while - then continues. Disconnecting serial control has no affect.
Bob Zelin
Re: Knox RS 16X16 HB "re-setting"
on Dec 4, 2010 at 3:57:29 pm
perhaps it's time for a new router.
This is an analog router, correct ? You can get a Kramer 16x16 for about 3 grand, that will be more reliable than the Knox.
If you were SDI (which I guess you are not), you could choose from the wonderful Blackmagic or AJA family, for the same price.
Bob ZElin
Ken Karns
on Jul 31, 2012 at 4:49:07 am
We have found the Knox switchers to be very reliable.Also,The Knox technical service I have found to be great.Even if your 16X16 is out of warrenty,they have a great staff thats always willing to help.Contact them at http://www.knoxvideo.com/ and click on tech support.
Hope you get some help with this problem
Ken Karns
NCIRradio
