stripes on playback of DVCPRO tapes
COW Forums : Broadcasting
steve swienckowski
on Apr 25, 2010 at 4:40:16 pm
Tapes from client all look like this:
http://www.davidcrane.com/dvcpro
Are there settings I need to change on my machine?
model AJ-D230H
Mark Suszko
Re: stripes on playback of DVCPRO tapes
on Apr 26, 2010 at 2:27:06 pm
DVCPro HD and DVCPRO 50 are not going to play in a DVCPro25 deck.
If your deck is a more advanced one that can play the HD and 50 meg flavors of DVC Pro, then I think all you need to do is go into the menu settings and change it to the correct format. Though a higher end DVC pro deck should be auto-detecting the format and adjusting to play it. You can also set a menu pref for that, I think.
What model deck are you using?
Micah McDowell
on Apr 26, 2010 at 5:03:21 pm
The AJ-D230H is definitely standard-def DVCPro25 only; no DVCPRO50 or HD support if that's the issue.
If the tapes do indeed contain plain ol' DVCPro25 footage, your deck have dirty heads or need repair.
