Interlaced to broadcast
COW Forums : Broadcasting
Christofer Wetterholm
on Nov 17, 2009 at 5:25:07 pm
Hello!
I could really need some help to clear things out..
I´m working on a project wich is going to be broadcasted on tv in sweden,norway and denmark
The footage i recieved from the client is interlaced PAl. UFF 25fps 1024 576
My job is to do the graphics and text in after effects and then render out a master file (Mpeg 2 and Quicktime)) to the broadcaster.
What is the best workflow so i get the highest quality possible?
Is it best to interpret the footage as UFF, do all the animation work and then render out the finished movie with fieldrender on. Set to UFF.
Or is it best to render it with fieldrender set to off.
If i understand everything correct then the first choise is better but i don´t know and i hope some of you do!!
/Christofer
maurice jansen
Re: Interlaced to broadcast
on Nov 21, 2009 at 11:16:36 am
your correct
if you use the last option all the things you ad will studder
greet
Maurice
People saying they don't make mistake's often make nothing at all!
