Side By Side Monitor and WF/VS options
COW Forums : Broadcasting
Joe Davenport
on May 4, 2009 at 6:58:40 pm
Hello all
Does any one have a readily available solution for a side by side rack mount kit with a lcd and a waveform/vectorscope? I want to combine a JVC DT-V9L1DU 9" monitor and a Videotek TVM-4DG in an all in one unit, but there isn't really a kit for that. The TVM should fit into the rack kit for the JVC monitor, but I will have to fabricate some rear support for it as the mount is not very deep.
I wanted to see if any of you guys have a workable solution in the same price range. Customer is set on the TVM-4DG, the LCD monitor could possibly be switched out with a Panasonic, but I would prefer using the JVC as I think it looks better(at least the 24" comparatively looks better than the 2550, IMO).
I talked to FEC mounts as they are the OEM for JVC, but they didn't have anything. The rack kit for the TVM is too small for the JVC.
Any suggestions are appreciated.
Joe Davenport
Re: Side By Side Monitor and WF/VS options
on May 12, 2009 at 1:59:17 pm
So, is everyone just using rasterizers these days?? No one doing the side by side thing anymore?
