HD-SDI on ethernet cable possible?
COW Forums : Broadcasting
Din noor
on Mar 25, 2009 at 9:58:34 am
is it possible to transmit HD-SDI signal on Gigabit cables(ethernet..).Using Fibre is costlier..any suggestion..
thks
Din
be calm & patience.
Bob Zelin
Re: HD-SDI on ethernet cable possible?
on Mar 29, 2009 at 10:35:26 pm
http://www.etslan.com/
I will not be calm.
bob zelin
Bob Zelin
Re: HD-SDI on ethernet cable - THIS IS THE ANSWER
on Mar 31, 2009 at 11:13:40 pm
The answer is yes.
HD-SDI over standard IP networks
Pure 3 Codec by Electrosonic Products.
888 343 3602
http://www.electrosonic.com
NAB booth SL9720
is this the info that you needed ?
Bob Zelin
Andrew Janowski
on Feb 3, 2012 at 7:36:51 am
Yes you can transport HD SDI over IP , using HD high definition encoder with the HD-SDI input and IP output , HD decoder have IP Ethernet input and different video outputs  HD-SDI is one of them , but also HDMI , component ,composite video , It is nice solution too because you do not need gigabit Ethernet ,we are using Thor HD video is encoded as a 15Mbps TS , Video quality is amassing http://thorbroadcast.com/sklep-207
http://www.thorbroadcast.com/
