HD-SDI to SD GigE
COW Forums : Broadcasting
Dennis Perov
HD-SDI to SD GigE
on Feb 24, 2009 at 4:27:18 pm
Hi All.
Can someone suggest me a solution to convert 9 HD-SDI to a SD GigE?
Thank you.
Dennis.
Bob Zelin
Re: HD-SDI to SD GigE
on Feb 24, 2009 at 9:26:38 pm
I am confused by your question. You have 9 HD SDI sources (like 9 HD-SDI cameras), and you
want to convert each HD-SDI source to Gig E ? What do you mean by this. Do you want to use Gig E cable instead of Coax cable? Do you want to have a storage system that runs on Gig E? Do you want to transmit all 9 HD-SDI sources over 1 Gig E cable via a multiplexer. If you would explain exactly what you are trying to do, maybe someone could help you. Do you want to DOWNCONVERT the 9 HD sources to SDI, and then transmit them over Gig E ?
Bob Zelin
Dennis Perov
on Feb 24, 2009 at 10:18:12 pm
Hi
Hi Bob,
Thank you for the quick reply, I'll try to make myself a little clearer.
>You have 9 HD SDI sources (like 9 HD-SDI cameras), and you want to convert each HD-SDI source to Gig E ? What do you mean by this.
I need to convert 9 HD SDI sources that come from HD cams, scale it down to SD, encode to MPEG2, mux with the rest of the 9 feeds and send it down the Ethernet as MPEG2-TS using multicast IP.
Well, once the signal is in MPEG2 TS and on Ethernet, it can be either GigE or ASI, unless I'm wrong.
No, not a storage but MPEG4 encoders that will further compress signal, which will be transmitted to web and mobile users.
Yes.
Pretty close: downconvert, encode to MPEG2, encapsulate to MPEG2 TS, mux with the rest, transmit over multicast IP.
Thanks.
Dennis.
Bob Zelin
on Feb 26, 2009 at 4:04:43 am
REPLY - you need 9 independent HD-SDI to SDI converters (you say SD - do you mean analog composite, component, or SDI? I will assume SDI) - this means that you need 9 HD-SD downconverters, like AJA HD10MD3 boxes.
REPLY - boy, I don't know how you are going to multiplex NINE HD-SDI or SDI signals into one signal. In audio land, this is what all the cobra net products do. But for video, I am unaware of any product that will do this.
REPLY - simple products like the Blackmagic Video Recorder will take the live signal in, and convert to h.264, for web and mobile users. But from a SINGLE FEED, not 9 multiplexed signals.
Yes.
REPLY - good luck.
Bob Zelin
Thomas Ballantyne
on Apr 7, 2009 at 8:17:41 pm
Hi Dennis,
Did you find a good solution to this problem? I have a similar set of needs - mux'ing 4 to 8 SDI video channels over 1gigE...
Thomas
Dennis Perov
on Apr 7, 2009 at 9:48:12 pm
Just a brute force cherrypicking.. DM 6400 with a GigE and a bunch of SDI cards.
Good luck.
Dennis.
Robert Hess
on Mar 19, 2012 at 11:46:52 pm
Sounds like you need a bunch of Hardware MPEG Encoders. Try Thor Broadcast equipment, I've had a lot of luck with it.
