Mulitple Video Monitor Software
COW Forums : Broadcasting
Lawson Moore
on Feb 20, 2009 at 2:07:04 am
I am trying to find out if there is a software that will take multiple feeds from a corresponding piece hardware and display them on the computer screen like a Multiple Video Monitor?
If so;
-would it adjust to the aspect ratio
-would it have safe zones
-I don't know what to ask
anything will help... thank you.
Bob Zelin
Re: Mulitple Video Monitor Software
on Feb 20, 2009 at 3:30:50 am
if you own a Panasonic AV-HS400A, this switcher will take 8 sources, and display it on one DVI or VGA screen. Without hardware that will take in multiple sources, how do you expect a "software only" product to get these video feeds into your computer ?
bob Zelin
Lawson Moore
on Feb 20, 2009 at 4:03:21 am
I didn't think this could be done without hardware... I was curious to know if there is hardware that will send the signal to a comp. and have the monitoring station open up like an application that can be used simultaneously with other apps. if this is so I could do what ever I wanted with the feed.
Mark Suszko
on Feb 20, 2009 at 6:57:02 pm
You probably would have better luck just using a multiplexer, there are many sources but all the big Brodacast guys, Sony, Panasonic, etc offer them in their security video divisions. Supercircuits sells some too.
