Broadcast Live Editing/Switch Softwar for OS X
COW Forums : Broadcasting
Andree Franks
on Feb 17, 2009 at 8:16:03 am
I'm not sure if this is the right forum but I would think you guys have information or experience in what we need.
Is there a Software out for the OS X platform to perform Live Editing or Switching (Video Mixer).
I have looked at Blackmagic Intensity Pro cards.
But we are not 100% sure if they are right solution.
Tyler Ries
Re: Broadcast Live Editing/Switch Softwar for OS X
on Apr 9, 2009 at 6:02:00 pm
A program that I have played around with (but never used for a real taping or broadcast) is Live Channel Pro by Channel Storm. This program allows you to connect multiple cameras (through Firewire or capture cards) and switch them live. The live stream can then be output through your computer's secondary monitor output or directly to a web stream. It also allows the use of keyed graphics that are made as PNGs. This program seems like what you are looking for, but I don't know anything about the performance. They have a full version for free that outputs with a water mark, so this would be a good way to test it and see if the program can handle what you are trying to do.
Hope this helps ...
Richard Cardonna
on Apr 10, 2009 at 3:56:54 pm
These are other alternative you can use them on a mac with bootcamp or maybe parallel.
http://avtake.com/
http://vidblaster.com/
http://www.moviecockpit.com/sys_req.htm
imop avtake is more for broadcasting though videoblaster does look interesting
RC
Andree Franks
on Apr 12, 2009 at 6:43:53 am
thanks!
This is more what we are looking for!
Only catch is we have up to 6 cameras.
Not sure if are IT section are willing to use windows on our Macs.
But it is for sure worth to pass it on.
Richard Cardonna
on Apr 13, 2009 at 11:49:24 pm
Unfortunately they are all limited to 4 fire wire cams. They say its a hardware limitation but i don't know if it has to do with thoughput or the lack of more than 4 fire wire ports on available mobos?
The only workaround i see to this (using the avtake) is to have 2 systems, the second feeding the the first through one of the 4 fire wire ports but this would need 2 directors and system one would have to rely on what system 2 feeds.
The only other software based mixing app that i know of is broadcast pix but its tied to its proprietary hard ware. This sytem looks great.
let us know how you work those challenges.
good luck
Richard C
MikeVersteeg
on Apr 21, 2009 at 7:18:25 am
Er.. Not sure where you got that info from, but VidBlaster Studio supports up to 99 cameras..
Richard Cardonna
on Apr 25, 2009 at 9:34:31 pm
That would be great, but how and what type of cameras?
RC
MikeVersteeg
on May 8, 2009 at 7:19:50 am
FAQ - How do I connect my cameras to VidBlaster?
Richard Cardonna
on May 21, 2009 at 3:18:42 pm
Dowmloaded studio did not see
1-support for 720x480 resolution.
2- only import png,
Is this a demo issue only?
R Cardonna
p.s Could i import animated giff and overly on image?
Richard Cardonna
on May 21, 2009 at 4:07:37 pm
Also, will record to avi be implemented soon?
R Cardonna
