Various Video Formats
COW Forums : Broadcasting
Janet Penny
on Feb 13, 2009 at 4:05:05 pm
Hi There,
I'm creating a program that requires using alot of various video sources. I'm editing on Final Cut Pro, in HD, 29.97 NTSC project. We're mastering the final product in 1080i 59.94 .
The various footage will likely brought in Quicktime Format. There will be instances where we may be bringing footage from tape.
Below is a list of the formats I am interested in using. How hard would these be to incorporate into my show? Would I need to get the footage upconverted/downconverted/terranexed, etc?
We also have window graphics that we may get created in a 4:3 manner in order to fit them into 16:9 frame, but I just wanted to see the logistics of this in general and how much trouble it may be. Hopefully this makes sense. Thanks in advance!
Examples:
1. Aspect Ratio : 16:9 Anamorphic
Original Line Standard : 625i/25 fps
Shot On : Digibeta
Available As : Standard
2. Aspect Ratio : 16:9 Anamorphic
Original Line Standard : 1080p/25 fps
Shot On : HD CAM
Available As : HDp Standard
3. Aspect Ratio : 4:3
Original Line Standard : Film
Shot On : 35mm
Available As : Standard HD From Film Film Backed
4. Aspect Ratio : 4:3
Shot On : 35mm
5. Aspect Ratio : 16:9
Original Line Standard : 1080i/59.94 fps (NTSC)
Shot On : HD CAM
Available As : HDi Standard
6. Aspect Ratio : 4:3
Shot On : D3
7. Aspect Ratio : 4:3
Shot On : Beta SP
Joey Burnham
Re: Various Video Formats
on Feb 13, 2009 at 6:44:14 pm
What's your budget? Makes a world of difference. If you can afford it have a post house transfer everything to the format you are mastering in. There are a host of issues with the transfers but if you choose a professional post house they will have the proper converters and staff to do a good job.
Wanna do it yourself? Not gonna be fun. Someone else will chime in though on the specifics of that.
Joey
Janet Penny
on Feb 13, 2009 at 7:20:35 pm
I will likely be getting it transferred at a post house. Budget is decent. I just wanted to see if any of the examples would be usable right off the "get go".
Joey Burnham
on Feb 13, 2009 at 7:24:27 pm
They will just run all the video stuff through a Teraxnex or something similar and you should be fine. For the film you will need to have that telecined out. What is your location?
