Legalizer DL-860 HD/SD or something else?
COW Forums : Broadcasting
Frank Koval
on Feb 11, 2009 at 3:27:18 pm
Hi!
Enybody use this equipment? - LEGALIZER DL-860 HD/SD? Please write Yours opinion about this. This is worth to buy? for working with AVID Nitris? Or maybe CoCo HD HD/SD colour corrector and legaliser? What is Yours advice? What is, in Your opinion, the best method for testing and compare this equipment for best choice?
Thanx and best regards
FK
Keith Troester
Re: Legalizer DL-860 HD/SD or something else?
on Feb 13, 2009 at 10:48:05 pm
We use the DL-860 with a Symphony Nitris, and it does a decent job. It won't always catch all your color peaks, especially if if they are as small as a frame or two (or, as I've seen, even a field). It's roughly the equivalent of Avid's safe limiter (I can't remember what the exact name is), but in hardware form. It deals with luminance well. Also, the advantage of SD and HD is always nice.
Hope this helps.
-Keith
http://www.keithtroester.com
PHOTOS | VIDEOS | SOUND | ETC.
Sanne Buurma
on Dec 3, 2009 at 6:43:38 am
You also might want to have a look at Axon's HDL100.
