how to export to tape using premiere pro CS3
COW Forums : Broadcasting
Erico Tenggara
on Dec 25, 2008 at 6:40:23 am
hi guys, i have a problem using premiere pro CS3. usually i use edius pro3 to print to tape, and now i have to use premiere pro to export tape to my betacam SP player. the problem is i can't insert my time code from premiere to tape, even i have already set the time code external in my betacam SP player. anyone know how to solve it? thx in advance
** Intel Quad Core Q6600, V-Gen 2GB DDR PC-6400, 2TB HDD, View Sonic VX1962WM 19", Digital Alliance HD 3650 **
Charlie King
Re: how to export to tape using premiere pro CS3
on Dec 25, 2008 at 2:56:11 pm
The best way to do this is prestripe your beta tape, then you can export in insert mode. When you start to make the cut to tape tell Premiere that you want to start the edit at 1:00:00:00 and it will do the insert.
I prestripe my tapes starting at 58:40:00 with bars and tone from 58:40:00 and cutting teh bars shortly after 59:40:00 when I start the digital cut to tape, I add slate to teh beginning of my project and possibly countdown after slate, starting the insert at 59:40:00 with 10 slate and ten for countdown program starts at 1:00:00:00.
Hope this helps.
Charlie
ProductionKing Video Services
Las Vegas, Nevada
Charlie@proking.net
Erico Tenggara
on Dec 27, 2008 at 1:18:35 am
Ok, thanks. Now I manage to print the tape. However the result is the tape doesn't get the timecode from premiere, the tape using the internal timecode. How to solve that? Thanks a lot, man
