NTSC vs PAL
COW Forums : Broadcasting
Oliver Dickinson
NTSC vs PAL
on Dec 10, 2008 at 2:43:46 pm
I live in France and was recently asked by a distributor from the US who works a lot in europe for a Beta SP master either in NTSC or PAL.
From there they will take care of any conversions.
Which system will be the best basis?
Andy Mees
Re: NTSC vs PAL
on Dec 10, 2008 at 3:16:18 pm
LOL. A bit more info would help Oliver!
A Beta SP of what? Something you have already produced or something you are still planning, or.. ?
If its something still in the planning stage then what kind of program is it? Where are you planning to shoot it, US, Europe, ... ? What format are you shooting in, HD/SD? Do you have a prefered frame rate? Where will this distributor be distributing your work, US, Europe or Worldwide?
Failing all that as a basis for deciding which format to go with then choose PAL ... far nicer than yucky NTSC
Andy
Oliver Dickinson
Re: NTSC vs PAL
on Dec 10, 2008 at 4:33:22 pm
The film is finished and was shot in DVCAM PAL.
Joey Burnham
Re: NTSC vs PAL
on Dec 10, 2008 at 8:23:01 pm
If he doesn't care leave it in PAL. Why waste you own time?
Andy Mees
Re: NTSC vs PAL
on Dec 11, 2008 at 2:26:07 pm
Exactly, Oliver. If your film is finished in DV PAL and the distributor has asked for a BetaSP master then give him a Beta SP PAL master. This will ensure that the source he receives is the best possible quality from which he can generate whatever other copies he needs.
Oliver Dickinson
Re: NTSC vs PAL
on Dec 11, 2008 at 4:13:57 pm
Indeed, I'll do that.
Thanks for the help guys.
I'll be back...
