Flickering Broadcast monitor on SDI signal only
COW Forums : Broadcasting
Robin Seymour
on Oct 9, 2008 at 1:37:03 pm
Hi All
I'm pretty sure this is a monitor issue. Thought maybe someone might be able to shed some light.
I'm working with a Blackmagic Design Multibridge Pro 2 box connected to a G5 Quad running FCP (all latest software).
I'm temporarily using my old JVC BM-H1400PNKA monitor as a b'cast monitor. I get a clear but rather shoddy image when connecting via the composite pal out on the MB Pro. When I connect the SDI out to the monitor I get a much clearer and richer image, but with flickering black lines over the image and a bit of a jitter. It looks like a synch issue, but apparently according to Blackmagic no synch is required for SDI. I'm using a standard BNC cable to connect (professional broadcast coax).
I'm pretty sure it's a problem with the monitor, but there are a very limited amount of things to fiddle with in the menu.
Any ideas what is causing this, and any solutions or workarounds?
Thanks y'all
Robin
Robin Seymour
Re: Flickering Broadcast monitor on SDI signal only
on Oct 9, 2008 at 2:40:37 pm
Meh, don't sweat it.
I just used the component input and it's fine. Pretty sure the SDI board on the monitor is shot.
