DVW-M2000 Digibeta Deck
COW Forums : Broadcasting
Eugene Gordon
on Aug 16, 2008 at 11:06:30 pm
DVW-M2000 Digibeta Deck I am having a problem dubbing a tape out of a Panasonic-AJ-HD1400 to the DVW-M2000 SONY Digibeta Deck I have a signal and am good using SDI. The record inhibit will not go away I have even found in the menu and made sure it was off. I am still unable of manually Play and Record on the DVW-M2000 Digibeta Deck.
Any ideas
Eugene Gordon
323-636-2039
Din noor
Re: DVW-M2000 Digibeta Deck
on Aug 26, 2008 at 1:31:54 am
hI there,
have you check on the tape itself?
did you Press in the red record inhibit plug. (“ON”)
Return this plug to its original position to enable recording on the
tape again. (“OFF”)..
thks
Din
be calm & patience.
