mini dv tape question
COW Forums : Broadcasting
Sam Lesante Jr.
on Aug 11, 2008 at 7:11:23 pm
I noticed that when i go to purchase mini dv tapes on some websites they have 3 different "grades" ranging from consumer to professional.
Is it worth spending twice as much on the professional or do you think the consumer one is just as good for using it to shoot hdv?
What's the difference in the 3?
TIA
Sam
Mark Suszko
Re: mini dv tape question
on Aug 12, 2008 at 2:17:27 pm
It could mean nothing. It could mean something. Meaning that it could just be marketing and packaging the same tape. Or it could be the pro-level tape has gone thru some more Q/C processes and higher standards for reliablity, etc. perhaps it is drawn from th emiddle of the original spool, where the tape is the best, maybe it has a slightly thicker magnetic coating, etc. We can't really know, unless someone has a reliable document to prove one is better than another on a scientific basis.
Considering tape is the cheapest thing we buy, except when it has failed, I don't think it's worth quibbling over an extra buck or two to get something that works for you. If you get massive dropouts on an irreplaceable tape, the client is not going to care that you saved two dollars over the high grade stuff.
Pick a supplier, test it out a while, then stick with the one brand.
Keith Troester
on Aug 23, 2008 at 12:13:02 am
Yeah, I agree here. Some of it's marketing, some of it isn't. I have still found that Sony is the most reliable in terms of drop outs and re-use. There's a reason networks like Sony.
My Weekly Comic for TV Techs: http://fpscomic.blogspot.com
Craig Berlin
on Dec 19, 2008 at 3:05:06 pm
I agree with Mark. Unlike analog, you may not see the difference in first generation picture quality but higher grade tapes do have higher coercivity and retentivity, which makes them better at attracting and retaining magnetic signals and less likely to have dropout. They also have a greater particle density and higher grade mechanisms. The professional grade products are subject to higher quality control and frequently come from a more consistent part of the pancake. Depending on your budget and the amount of footage, a couple of extra bucks to 10-12 bucks a tape may be gilding the lily or it may be the difference between a successful shoot and a failed one.
Craig
http://www.pro-tape.com
