422 cable length
COW Forums : Broadcasting
Mathieu Marano
422 cable length
on Jul 29, 2008 at 7:02:19 pm
I have to install a 422/9-pin cable between my two machine rooms. What would be the maximum length I could use? I think I have 150 feet between both patchbays.
Do you know where I could find a wiring diagram for that purpose because I will have to make the cables myself.
thanks
Mathieu Marano
online editor - motion graphics - Post-prod director
Directeur technique de post-production
Le Bureau de post production
Administrator of the Montreal Final Cut User Group
http://www.finalcutmtl.org
Bob Zelin
Re: 422 cable length
on Jul 30, 2008 at 1:14:10 am
One thousand feet. 150' is NOTHING for RS422 transmission.
This is the wiring diagram - you need 2 9 pin Male D connectors.
You will wire them PIN TO PIN -
1 -- 1
2 -- 2
3 -- 3
4 -- 4
5 -- 5 (5 is not used)
6 -- 6
7 -- 7
8 -- 8
9 -- 9
Hope you are good with a soldering iron. The easier way is to get a CAT 5 cable, and RJ45-9 pin male adaptors.
If you are running digital video 150', if you don't use good video cable (like Belden 1505A, Gepco VPM-2000 or Canare L-4CFB), your SDI or HD-SDI video signals will never make that distance (if you use cheap crap old RG-59 video cable).
Bob Zelin
Mathieu Marano
on Aug 13, 2008 at 2:37:07 pm
Thanks, it went pretty well. I only damaged one connector before I got it right. Both the SRW-5500 and DVW work fine on 160 feet of RS-422 to the offline station on the other side of the building.
I also installed a 3G ready AVP patchbay. All that's left to install is a RJ-45 patchbay to send the vectorscope/waveform VGA monitor output to the online rooms. I bought 6 eight inch iKan monitors. They work very well for that purpose.
Mathieu Marano
Bob Zelin
on Aug 13, 2008 at 9:37:37 pm
Isn't AVP an amazing company. They are not well known in the US, and it's a little tough to get distribution (compared to ADC and Canare), but their patch bays are FANTASTIC (I like them much better than ADC).
Glad it all worked out for you.
Bob Zelin
