Progressive Footage for Broadcast
COW Forums : Broadcasting
Teresa Brown
on Mar 31, 2008 at 7:14:59 pm
I've been delivering interlaced dubs for local broadcast projects, but would like to try shooting progressive for improved chroma-key results. Will I need to convert the master back to interlaced in some way before dubs are made? How would this be done in Final Cut Studio? Is this even possible?
Del Holford
Re: Progressive Footage for Broadcast
on Apr 2, 2008 at 6:22:57 pm
My edit system allows me to use either interlaced or progressive on the timeline so often the background footage is interlaced and the key is progressive. On moving type, this sometimes eliminates jitter that makes the words blurry. I also import graphic files (usually tif format) as progressive so when I do moves on the picture the video stays sharp. Since CCIR 601 (standard definition) video is interlaced, my projects are set up and eventually output as interlaced. HTH
Del
fire*, smoke*, photoshopCS3
Charlotte Public Television
del underscore edits at wtvi dot org
