Replacement for SGI monitor
COW Forums : Broadcasting
Mathieu Marano
on Feb 8, 2008 at 8:09:21 pm
Hi guys,
I have a Flame workstation running on SGI. I have a GDM FW9011 SGI display attached to it with RGB HD VD cables. I am trying to find a display to replace it that would also have DVI input for a second windows-based station. I would like to be able to use the same display for both.
Any suggestion?
Mathieu Marano
Del Holford
Re: Replacement for SGI monitor
on Feb 11, 2008 at 6:31:26 pm
We recently replaced our SGI crt in smoke with an HP 2335 LCD and it works fine but the Octane2 needs sync on green so it uses the 15 pin with an adapter. That only leaves RGB and composite in on RCA connectors. That might work for you if the Windoze machine can output to that. I think the 23" version is now a 24" version but is otherwise the same.
http://h18000.www1.hp.com/products/quickspecs/12450_na/12450_na.PDF HTH
Del
fire*, smoke*, photoshopCS3
Charlotte Public Television
del underscore edits at wtvi dot org
