Commercial for local tv station, Need Help
COW Forums : Broadcasting
Jason Sanders
on Jan 16, 2008 at 1:03:13 am
Ok, so i do short films and all the fun stuff you can do with a camera. A company wants me to do a couple(3) commercials for Local TV broadcast. I have only done one and that was with a lot of help. What i'm asked for is to use footage they supply, add my own, and piece it all together.
What do i got?
Well i'm using there footage(previously shot), generating my own BG, and texts in AE cs3 and Premiere.
Equipment:
CUSTOM: core 2 quad core 2.4ghz, 1x80gb SATA (OS), 2x500gb SATA II (storage), xp pro x64...and more
my main question(s)are:
1.what "levels" should i set everything to for AE/Premiere Pro CS3
2. Audio..what levels as well i've heard -10 db, -12- and -20 db???
3. Format, i have a mini-dv (canon GL2) what are my options, hjow necessary is "beta" i have researched and they are very pricy!! especially for these lower end projects.
thank you in advance to anyone who can advice anything from here, my previous commercial is here:
http://www.hecticfilms.com/index.php?option=com_seyret&Itemid=29&task=video...
Thanks!!!!!!!
Jason Sanders
Mathieu Marano
Re: Commercial for local tv station, Need Help
on Jan 16, 2008 at 2:18:05 am
Black no lower than 7.5 and white no higher than 100Ire.
For Saturation, no higher than 100
You better check with the broadcaster for specs
Usually, you will need 2 kinds of meters to evaluate your sound: VU and Peak.
Your sound should not go over -12 or -8 dBs PEAK and be between 0 and -7dbs on your VO meter calibrated at -20 or -18
Bring your project or final quicktime to a local post facility to get a Beta
Mathieu Marano
online editor - motion graphics - Post-prod director
Directeur technique de post-production
Le Bureau de post production
Administrator of the Montreal Final Cut User Group
http://www.finalcutmtl.org
Jason Sanders
on Jan 16, 2008 at 8:43:08 am
Awesome! Thanks for the quick response! That sounds perfect!!! I will try these settings ASAP. Is there any kind of "plugin" or any universal-type setting, such as" apply broadcast color bars at intro for seconds followed ny a tone" and if so, where do i get such things, i have heard of countdown leaders, smtp, bars, tones, etc. anything sound like what you would use as a standard for submitting to a tv station? thanks again for your help
Jason Sanders
Mathieu Marano
on Jan 16, 2008 at 9:43:31 am
There is no "plugin" but I'm sure you have a 75% smpte color bar to use somewhere in Premiere.
The typical sequence here in Montreal is:
09:59:00;02 Color bar w/tone
09:59:40;00 Slate with commercial number, length, prod
09:59:50;00 black
10:00:00;00 PROGRAM
Some broadcasters prefer their commercials on a NON-DROP tape.
Mathieu Marano
Jason Sanders
on Jan 16, 2008 at 7:31:03 pm
Great! Thanks Sooo Much!This will definitely get me going where i need to be. You have been a great help and thanks for the fast reply!
Jason Sanders
