Broadcast colors question again
COW Forums : Broadcasting
Sam Vargas
on Feb 19, 2007 at 2:38:44 pm
Are broadcast color restrictions apply for DVDs and other footage viewed on TV ?
Or just video through broadcasting?
Del Holford
Re: Broadcast colors question again
on Feb 19, 2007 at 3:30:59 pm
While FCC rules generally apply to transmitted video, the implementation of those rules may help your video project look cleaner on a DVD or video presentation. The rules are there to keep chroma from being oversaturated and smearing; to keep extended blacks from running the transmitter at 100% power for too long; to keep white levels from causing a buzz on the older analog TVs; etc. So while some rules don't apply (you don't have to worry too much about transmitter power) they can be guidelines to help make your project more pleasing to the end user.
Del
fire*, smoke*, photoshopCS2
Charlotte Public Television
Charlie King
on Feb 19, 2007 at 4:46:26 pm
I agree totally. If you create everything as tho it was to be broadcast, your quality of all projects will be uniform and in the long run everything will playback cleaner and better.
Charlie
