Broadcasting best format
COW Forums : Broadcasting
Fedodeomedo
on Feb 7, 2007 at 12:51:54 pm
Hi all, can i know what is the best video format for broadcasting??? In fact i am using MPEG2, but a lot of my clients ask me to use AVI (DV PAL). So can any body help me please??
Matte
Re: Broadcasting best format
on Feb 7, 2007 at 3:02:38 pm
Broadcasting WHERE and what kind of program?
You need to provide MUCH more information.
Del Holford
on Feb 7, 2007 at 5:45:25 pm
The best format for broadcast video currently is HD at 1080p downconverted to 1080i or 720p. This can be at 25 fps or 29.97 fps depending on the national standard where you reside. Output to D5 or HDCamSR and you have nearly uncompressed video for broadcast playback. Then transmission takes over and reduces bandwidth by extreme compression.
Del
fire*, smoke*, photoshopCS2
Charlotte Public Television
FEDODEDOmedo
on Feb 8, 2007 at 8:34:02 am
we are using play box broadcasting system with black magic deckling( 720*576 25 fps pal system), as i know we have only tow choices to properly broadcast by play box system, MPEG 2 and AVI DV. So if you please what video codec type do you recommend??
